I have some 25p (partly field blended) MOV files that I am trying to restore. The overall quality is good, but it has 2 issues I can't seem to resolve:
80MB MOV Sample [00:10]: https://www.dropbox.com/s/n2iiqgu51bpnydi/LK-MOV-sample1.rar
1. Vibrating frames - The progressive frames are slightly vibrating left/right. I used Deshaker in VirtualDub, but it did not return the expected result. Settings that I used:Originally Posted by Smaller, compressed samples
2. Some frames have white specks.
I like using RemoveDirtMC(25, false) as it works works well, but it is not working as expected in this case. RemoveDust(1) or higher does a good job at diminishes the specks, but it also takes away significant details from the picture.
Please advice.
Results 1 to 30 of 44
Stab seems to stop the shaking. This seems to get rid of the spots while Dilip Kumar is on screen:
SeparateFields
Ev=SelectEven.RemoveSpotsMC3X(30,false)#Thanks, jagabo
Od=SelectOdd.RemoveSpotsMC3X(30,false)
Interleave(Ev,Od)
Weave()
But I couldn't figure out how to get rid of the white specks after the scene change. And I don't know why not either. I put Stab after the RemoveSpotsMC3X lines. -
Thank you! Please upload your sample because Stab() didn't work as anticipated. Did you call Stab() with default parameters? I have found 4 different versions of Stab() on doom9: http://pastebin.com/KhQQMMrM
Another sample with more noticeable vibration: https://www.dropbox.com/s/dvrjhatdxsgdbyv/LK-sample2.avi
The following works better, but the face loses details. Any way to calm it down?
Code:SeparateFields Ev=SelectEven.RemoveSpotsMC3X(30,false).RemoveDust(1)#Thanks, jagabo Od=SelectOdd.RemoveSpotsMC3X(30,false).RemoveDust(1) Interleave(Ev,Od) Weave()
If the specks remain only during those transitions but RemoveSpots works well elsewhere, it's easy enough to apply it only during those times. If you're willing to make your way through the entire film looking for such places. Or turn those transitions black. I'm not all that fond of them, myself. As for Stab, yes, I modified it a little bit:
#Original script by g-force converted into a stand alone script by McCauley #
#latest version from December 10, 2008 #
#mirror - fill empty borders with mirrored from frame edge pixels (instead of black):
# 0 - no mirror (default);
# 1 - top;
# 2 - bottom;
# 4 - left;
# 8 - right;
# sum any of above - combination (15 - all ).
# From Depan
function Stab (clip clp, int "range", int "dxmax", int "dymax") {
range = default(range, 5)
dxmax = default(dxmax, 8)
dymax = default(dymax, 8)
temp = clp.TemporalSoften(7,255,255,25,2)
inter = Interleave(temp.Repair(clp.TemporalSoften(1,255,25 5,25,2)),clp)
mdata = DePanEstimate(inter,range=range,trust=0,dxmax=dxma x,dymax=dymax)
DePan(inter,data=mdata,offset=-1,Mirror=5)
SelectEvery(2,0) }
ffindex("LK-sample2.avi", demuxer="lavf")
FFVideoSource("LK-sample2.avi")
SeparateFields
EV=SelectEven.RemoveSpotsMC3X(30,false)
Interleave(Ev,Od)
Weave()
Stab()Last edited by manono; 10th Mar 2014 at 01:27.
Thanks for the modified function. It does seem to make a difference, but not completely get rid of it. Would you happen to know could have caused this jitter, and if it is possible to completely get rid of it by either modifying stab further or by making multiple passes of Stab()?
As for the spots, I am trying to modify the RemoveDust function. I have never done so before, but no harm in playing with it. Anything else I could try without damaging the details? -
Stab is designed to fix gate weave - the wobbly effect seen when the sprocket holes of film get enlarged through use. I don't know if your source is caused by that or not as it doesn't look exactly like it. Anyway, since what you supplied isn't the DVD, you get what you pay for. Plus, Indian DVDs are the worst in the world. There are lots of other AviSynth filters designed to get rid of specks and dirt on film. RemoveDust is old and one of the last I'd try.
...if it is possible to completely get rid of it by either modifying stab further or by making multiple passes of Stab()? -
Stab, or any other deshaker, isn't going work with video like that. Different parts of the picture are moving differently. If it managed to deshake one part of the frame the other parts would be shaking.
RemoveSpotsMC isn't going to get rid of the spots in that fast panning shot, there's too much change from frame to frame. -
Although there are powerful methods described in this thread, I've removed spots like that manually when such algorithms didn't detect them.
It was successful, but not easy or quick. You can do it through a video editor, or even a photo editor (if you don't mind the color space conversion for those few frames), but I was wondering if there's an easier method using a tool with a simple scrub through VirtualDub and/or Avisynth preview?I hate VHS. I always did. -
No deshaker or motion interpolation filter will help. The videos were deinterlaced and alternate frames were discarded. The sample1.avi has stutter back-and-forth because the field order was reversed during deinterlace.
Standard definition PAL AVCHD is usually 25i interlaced.Last edited by sanlyn; 19th Mar 2014 at 02:27.
I tried the following, but it doesn't do what I was hoping it would
Code:Stab() turnleft.Stab().turnright
Would you recommend Photoshop or is there a better tool for this kind of work?
Thanks for the information. The video is mostly progressive with random interlaced sequences, especially the songs/dances and some high motion scenes for fluid movement I suppose. -
It's a movie, right? Then there should be no interlacing. It may be phase-shifted in parts. But it's just more evidence of it coming from a crap Indian DVD. No, not for fluid movement, not if it's from film. From incompetence. If you uploaded a small piece with the interlacing we could have a look.
Would you recommend Photoshop or is there a better tool for this kind of work? -
What is the source of these MOV files ? Were they derived from a DVD ?
Was anything else done to the AVI samples you uploaded (besides re-encoding) ? -
I understand. I will look up some frame interpolation techniques to make the best use of it. I am not experienced with MVTools, but I will go through it today. For now, I have used QTGMC to get rid of it and the result is quite nice.
I am not aware what the source is because we were recently handed over this 5 - 10 year old data for restoration. Judging from the uncropped and tilted frame sequences, the source does not appear to be a DVD.
I encoded it with x264 to give you an idea what I am working with. I didn't think people would be willing to download big samples. I will add direct MOV clips in the main post in a few moments and notify you guys. I will be sure to do the same in the future.Last edited by LaKap; 10th Mar 2014 at 17:09.
Will do. Thank you!
Quick question about RemoveDust(). I realize it is an old plugin, but effective for speck removal and overwhelming on details. I am wondering if there is an alternative to RemoveDust which does better decision making to handle certain white/gray pixels and leave the details/useful grain alone?
P.S. I am well aware of the garbage in, garbage out reasoning. Just want to find the limit to which we can restore this video.Last edited by LaKap; 10th Mar 2014 at 17:42.
Just a note - the MOV is uncompressed 8bit 422 . You can reduce the filesize about 1/2 or more just by using archiving software (e.g. winrar, 7zip, zip etc...) . People are more likely willing to download a 100MB sample, than a 200MB sample
It has field blends, but this sequence doesn't have the "vibrating" pattern as featured in the 1st two
That pattern in the 1st two samples looks to me like someone attempted stabilization, but not on full frame (motion block stabilization) . Those are the type of artifacts and partial frame morphing that you get -
Originally Posted by LaKap
Keep in mind, you are going from YUV->RGB->YUV, but working in lossless will produce better results.
But it's still work, and not automatic.
Then again, this is how some studio level software, priced 10K-100K US$, works (with auto and manual modes) - directly from all the project's frames loaded as images on a server. However, those folks do it for a living, or when profitable, and worth it for the professional productions at that stage.I hate VHS. I always did. -
Originally Posted by manono
Again, we're assuming manual solutions for residual spots that failed detection from automatic solutions.
Then again, if one doesn't mind the processing, you can run a script at least two dozen times if it's not too damaging on a video.I hate VHS. I always did. -
Photoshop extended can open video directly , and export MOV or AVI directly . Another commonly used tool is After Effects - very useful layer based masking/ rotoscoping/ motion tracking with some photoshop tools like clone stamp. It depends on how much effort you want to put into things
I would enquire about the workflow history for this MOV, and if anything else is available closer to the original, original source
The tiny white specks are on 75% of the frames so manual work won't be feasible, but I will certainly look in to it for future projects. -
Originally Posted by LaKapI hate VHS. I always did.
That's cool. I haven't upgraded my PhotoShop in years, and use VideoStudio for most of my edits, so this is news to me - this can shorten the workflow's cycle tremendously (which it sorely could benefit from).
That "vibration", partial frame morphing is really #%^$^ annoying. As mentioned earlier, no "automatic" stabilizer will fix it.
The only way I can think of "fixing" it is with a lot of manual work, masking and layers .
Only the progressive parts have the vibrating pattern. I used QTGMC to get rid of the blending.
QTGMC won't get "rid" of the blending, it will probably introduce more blending (The "T" in QTGMC stands for temporal) -
I will do some test encodes to see what the final output with rest of the script looks like. If it is visually distracting, then perhaps manual work will be the way to go. It would be helpful if you could please recommend some guides/videos to get familiar with the manual work you have mentioned above.
Well it's distracting to me, but your average viewer might not notice it that much. Avergae viewer probably don't even notice dirt/scratches that much. So I guess it depends who your audience is, and their expectations
Which manual work specifically? Did you mean treating the "vibrating" frames, or refining the dirt removal with layers and compositing ? It's a lot to go over - a lot of it falls under "advanced" - because there are many concepts and tricks used here , and each scene is slightly different and might use slightly different techniques. It's not one or two tutorials, but maybe ten or twenty or more that you have to take some concepts from. Even if you're familar with the tools and jargon used, there is quite a bit of a learning curve and a lot of manual work involved. I use avisynth because it reduces the amount of manual work in many situations. Very useful. I can outline how I would approach it if you like
VHS "Vertical Jumping"
By thisguyknows in forum RestorationReplies: 4Last Post: 21st Jan 2014, 07:35 -
"Blade Runner", MPC and region removal softwares
By thinredline in forum Software PlayingReplies: 6Last Post: 8th Nov 2012, 18:55 -
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 08:39 -
Whats the "material/texture" of the White Injet & White Therm
By ty1er in forum MediaReplies: 4Last Post: 25th Jun 2009, 08:24 -
how does one create a "blocked white" quote box in forum posts?
By PosRole in forum FeedbackReplies: 11Last Post: 24th May 2009, 03:46
